01-20-2012 12:16 PM
We are students from Oklahoma State University and we are working on a project where EMG data is collected using NI 9234 and NI 6210.
When we posted in the forum earlier while asking for suggestions of what board would be suitable for EMG data acquisition, some engineer from NI replied saying USB 6210 is enough for getting EMG signals. We had already got NI 9234 for some other project. We tried using both the boards for EMG data acquisition. But from the results, it looks like NI 9234 gives better signal than NI 6210. The signal from 6210 is dominated by noise.
I am using same kind of configuration for both the boards.
1) Pseudodifferential mode for NI 9234 and Differential mode fro NI 6210.
2) We are using Myoscan sensor interfaced with Sensor Isolator from Thought technologies as input to both the DAQ boards
3) The voltage range set for both the boards is -5 to 5 millivolts
I would like to know why the signal from NI 6210 is dominated by noise and whether is there any way to improve the signal.
I am attaching the screen shot of both the outputs for your reference.
Haritha Srinivasan
01-23-2012 06:01 PM
Hi Haritha,
How is your sensor connected to the NI 6210? How many EMG signals (or other kinds) will you be working with? Are both devices necessary for the application? As an additional side note, the NI 9234 is a more precise device and has higher resolution than the NI 6210. Hopefully we can improve the signal from the NI 6210.
Cheers,
Carisa
01-23-2012 06:49 PM
Hi Carisa,
01-24-2012
04:32 PM
- last edited on
07-23-2025
12:36 PM
by
Content Cleaner
Hi Haritha,
I've linked to two documents below that should be able to help you with the wiring and noise you're experiencing with the 6210.
Field Wiring and Noise Considerations for Analog Signals: https://www.ni.com/en/shop/data-acquisition/measurement-fundamentals/field-wiring-and-noise-consider...
6210 Manual (Pinouts on page A-2): https://www.ni.com/docs/en-US/bundle/usb-621x-manual/resource/usb-621x-manual.pdf
How to Eliminate AC Noise: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MnMSAU&l=en-US
Please read through these, try some of the suggestions and let me know how these work out for you.
Thanks!
Best,
Carisa
