Complier Error - Using Nidaqmx.lib Ver7.5 in Borland C++ Builder
Hi Daniel,
Would you be willing to post me an example of your
working Borland C++ code for analog input/output and/or
digital input/output? I am getting some weird run-time
error message (see my posting above) and don't know now where to search for the problem.
Any help would be highly appreciated.
Polero
Message 11 of 15
(2,155 Views)
I'm working on my project and I have just the possibility to read and write on Digital Port.
I try today to implemente on my application the sample "OneSample.c" for take only one measurement fron an analog Input Channel. But this code provoke a exception error:"EZeroDivide"!!!
What is that somebody would have already met this problem or can help me??
Thank a lot, and tomorrow normally I try to implemente a voltage level on a analog Output on my USB 6009 module!!!
Message 12 of 15
(1,905 Views)
Hello Bulot and Polero,
Please see this thread about the divide by zero error at DAQmxStartTask.  I think that it would be best to take John's advice and turn off the divide by zero notification in Borland.  It seems that our supported compilers like Visual Studio by default have this option turned off, but Borland has it turned on.  Let us know if this helps.
Laura
Message 13 of 15
(1,894 Views)
Hi Laura and Polero,
I've just found the solution of the error on my application.
The solution was to update my computon on the NIDAQmx 8.0 driver, but I met the same problem  when I had insert on my application the NIDAQmx.h and NIDAQmx.lib resulting of this new driver.
But when I compile my application, I have find a old Error.
The Final solution for my application run correctly, was to use de NIDAQmx.h of the NIDAQmx 8.0 and the NIDAQmx.lib of the NIDAQmx 7.5.
Link for the NIDAQmx 8.0 driver:
http://digital.ni.com/softlib.nsf/websearch/4C9E45F6EE5C29F9862570890071
On I join the .lib and .h how works correctly on my application.
Thank a lot of your help
See you
Bulot
Message 14 of 15
(1,888 Views)
I had this problem and used the borland coff2omf with the defaults and it seems to work for the 6009 code
Message 15 of 15
(1,148 Views)
