Computer reboots when Max is opened
With NI-Daq installed the computer reboots anytime Measurement and automation is opened. I have tried NI-Daq versions 6.8, 6.9.3 and 7.4. It doesn't matter if the PCI-MIO-16E-4 card is installed or not. If Ni-Daq software is installed, the computer will reboot when Max is opened. Uninstall Ni-daq and no issues are noted. I can communicate with a PCI-GPIB card just fine. This is on a Windows 2000 machine and it worked fine. Came in one morning and this just started happening.
(2,999 Views)
Try uninstalling NI-MAX and all associated drivers. Go ahead and delete the MAX forder at: C:\Program Files\National Instruments\MAX when you have finished. Then install NI-ADQ 7.4. This should fix the problem.
Let me know if this issue continues.
Sean C.
(2,984 Views)
