Concurrent Tasks - CompactDaQ 9178 with C Modules 9214 and 9211
I am trying to use a NI 9178 CompactDaQ together with c-series modules 9214 (cDAQ1_Mod4_AI in attachement) and 9211 (cDAQ1_Mod5_AI in attachement) to sense a total of 18 temperatures.
In attachement you will find a sample code where I try to create two concurrent tasks to read the temperatures. The reason I split the tasks into two is because eventually each task will be integrated in a different .vi that will run simultaneously.
When I run the code I get error code -50103: The specified resource is reserved. The operation could not be completed as specified.
I am having trouble understanding this as:
1) I am only using 2 AI tasks which is less than the limit (3)
2) I am not reusing physical channels in different tasks
Is the problem a timing issue? or does the NI 9214 simply not support multiple tasks?
Thanks in advance,
Best,
Sherif
(1,283 Views)
While your chassis can probably support 3 AI tasks, most individual modules can only support 1.  So be sure to put all the channels from a given module into the same task.   In this case, that'd mean 16 channels in a Mod4 task and 2 in a Mod5 task.
-Kevin P
(1,255 Views)
Thanks Kevin,
Makes sense ! That's what I unfortunately feared.
I'll have to create some kind of workaround for my application as I need the task in two .VIs.
Thanks again for your help,
Best,
Sherif
(1,218 Views)
