Configuring AMUX-64T with NI PCI-6034E
I'm trying to configure a AMUX-64T Multiplexer board with a NI PCI-6034E DAQ Card.
In MAX when I go to the properties of the DAQ Card to choose the acessory the AMUX-64T isn't in the drop down list.
I'm using Labview 7.1 and have tried a few different versions of MAX from 2.2 up to 4.5.
When I run my application I get Error code 10401 but its because I can't configure the AMUX-64T board.
(3,142 Views)
Hi JayC,
The error that you are seeing is an error associated with trying to convert code up from originally using TradDAQ drivers. Are you bringing this code up from previous versions or to a different OS?
http://forums.ni.com/t5/LabVIEW/error-10401-with-pcie-6321/m-p/1856115#M631404
Here is the link to DAQmx 8.9 that is the latest version of the DAQmx driver that will allow you rebuild in LabVIEW 7.1 but only up to Windows Vista.
http://joule.ni.com/nidu/cds/view/p/id/1216/lang/en
Could you let me know what you think about this?
Many thanks
Liam A.
(3,133 Views)
