Configuring ethernet port without NI MAX
I want to connect NI cDAQ 9188 chassis onto a windows 10 device. For that, I have installed NI DAQmx 17.1.1 runtime. While using ethernet, I found that it is already reserved for LAN by corresponding driver. I do not want to install NI MAX from NI DAQmx because of space constraints. So I would like to know if there is a way to detect chassis from device manager settings or command prompt or any other thing like that.
Message 1 of 1
(2,236 Views)
