Configuring executable labview programs originally configured with a PCI-MIO-16XE-10 on a system with a PCI-MIO-16XE-50 card
I'm hoping someone can help me. I have executable labview programs created in another lab which used a PCI-MIO-16XE-10 card. I need to install these programs in a new lab which has a PCI-MIO-16XE-50 card installed. When downloading the executable files, Measurement and Automation Explorer gave a message that the physical devices could not be located. I presume this is because the executables are configured for the PCI-MIO-16XE-10 but the PCI-MIO-16XE-50 is installed instead. Any suggestions on how to get these programs configured with the PCI-MIO-16XE-50 would be greatly appreciated? Thanks.
(3,204 Views)
As long as you have the device identifier of the PCI-MIO-16XE-50 set the same as the PCI-MIO-16XE-10 for which the program was written, you shouldn't have a problem doing what you describe.
One thing that confused me about your posting, however, is the statement When downloading the executable files, Measurement and Automation Explorer gave a message that the physical devices could not be located. This doesn't make sense to me. You're getting an error from MAX when downloading your program? MAX shouldn't be involved at all here, and especially not when just downloading your program. If you can provide more details about exactly what you are doing (maybe post some screenshots) then I'm sure we can help you get your program working.
Good luck,
Joe
(3,200 Views)
