Configuring task and sampling rate for multiple channels
We are creating our application using NIDAQmx API and I would like to make sure that I have understood certain basic concepts. If we have to channels and we need to sample them 500 kHz for each channel we can do it by following call: DAQmxCfgSampClkTiming(taskHandle,"", 2*500000, DAQmx_Val_Rising, DAQmx_Val_ContSamps, 10*2*500000)); When samples for both of the channels have been read, we want a callback to be called: DAQmxRegisterEveryNSamplesEvent(taskHandle, DAQmx_Val_Acquired_Into_Buffer, 2*500000, 0, &onSamplesRead, this)); In our read callback we can get the samples using: long __cdecl onSamplesRead(TaskHandle taskHandle, int32 everyNsamplesEventType, uInt32 nSamples, void *callbackData) { ... bufferSize = 2000000; DAQmxReadAnalogF64(taskHandle,2*500000,10.0,DAQmx_Val_GroupByChannel, data.get(), bufferSize, &read, NULL) ... } Are we doing everything correctly or is there some error in the sampling rates?
Message 1 of 1
(3,070 Views)
