Connect 6349 card to 1071 chassis
I am attempting to replaced an old PXIe-6366 card with a 6349 within my 1071 chassis. I have connected the new card but I do not see it appearing within the windows device manger, not do I see it appear when i start up Labview. I suspect that there is a missing device driver but whenever I attempt to install the NI Device Driver software I get a notification stating that I need Windows 7 service Pack 1 (the machine is running Windows 7 Professional, not sure if there's a difference).
(931 Views)
Both use the same DAQmx driver and I don't expect you to install it again if you had it working for 6366 in the first place.
About SP1, no, it is not the same as base Win7.
Santhosh
Soliton Technologies
(908 Views)
