Connect multiple USB DAQ cards to one computer
Hi All,
I have a unique application where I will need to simultaneously connect a multifunction DAQ unit (NI USB-6008) and two USB Thermocouple DAQs (NI USB-9211A) to one computer.  I wish to read, display and save the data from all 3 cards simultaneously via LabVIEW.  My computer has 3 USB ports, so is it possible to connect the three DAQ units directly to my computer?  Or would I need a USB hub to reduce all three into 1 USB port?  If neither of these methods will work, is there another option I could use?
This is not a long term solution (I'm setting it up for a day or two to run some tests) so long term stability isn't really a concern.  Any comments at all will be helpful, thanks very much.
(5,210 Views)
Hi pshadlyn,
You should be able to connect all 3 USB DAQ devices to the seperate USB ports. You should not need a USB hub to reduce them to one port. This would probably yield worse performance as I would expect using a USB hub will share the bandwidth on the port between all 3 devices. It would also probably be better if you had a seperate USB controller for the seperate ports in terms of high speed acquisition, but I think you should be fine with the rates of the USB-6008 and USB-9211As.  Let us know if you have any issues.
(5,189 Views)
I am using two DAQ units NI USB 6210 and NI USB 9171 simultaneously to read data via LabVIew. Were you able to find any solution to this issue?
(4,536 Views)
There was no problem to solve in the original question. What specific issue do you have? Provide details such as any error codes you get.
(4,532 Views)
