Connect your NI PCI DAQ card to your Laptop
Make your NI DAQ system more portable with a Magma PCI expansion system.
Magma PCI expansion products enable to use your existing powerful PCI cards
by connecting them to your laptop though its Cardbus (PCMCIA) slot.
Amplicon Liveline provides the full range of Magma PCI expansion products
from single PCI slot solutions to 13 slot solutions to suit you every need.
Verified by NI, you can check you NI card for compatibility click here:
http://www.magma.com/pci/compatibility/matrix/pc.html
Unsure that you laptop will be compatible? Just click here:
http://www.magma.com/pci/compatibility/pdf/pc_laptop_rec.pdf
For secure online ordering from Amplicon Liveline in the UK, click here:
http://www.amplicon.co.uk/dr-prod2.cfm/secid
/5/subsecid/10058.htm
Want to take a test drive first? No problem just contact one of Amplicon's
qualified Sales Engineers and arrange your evaluation today.
Click here for contact details:
http://www.amplicon.co.uk/dr-contact.cfm
Message 1 of 1
(3,309 Views)
