Connecting I/O to a PCI-6224
Can anyone give me guidance on how to connect SSR I/O modules to the PCI-6224 and SCB-68
(3,124 Views)
Hello Andy,
After looking at the product page of the device, I think you will need need a 50-pin IDC to 50-pin edge connector ribbon cable. Something like this. From here you can use a Breakout board to connect it to the SCB-68.
I don't believe that this would be the best design for your application. I would instead use a custom cable to connect the SSR I/O modules to the PCI-6224. I think this would reduce the amount of losses induced by multiple connections.
(3,103 Views)
