Connecting a cDAQ-9178 to a cRIO-9081
I want to connect a cDAQ-9178 chassis to a cRIO-9081USB port.
The cRIO-9081 has Windows Embedded 7 on it.  I have written a LabVIEW FPGA program that gets loaded into the cRIO's FPGA.  Once the FPGA is started, the FPGA basically ignores the Windows side, very minimum data exchange.
I want to use the WIndows side to run a cDAQ program.  I have to do it this way because the cRIO has 7 modules in it and the cDAQ has 7 modules.
Whenever I insert the NI-DAQmx 14.5 CD into a CD drive on the cRIO, I only see the cRIO drivers.  How do I get  the cDAQ drivers installed?
(4,861 Views)
Accepted by topic author Paul_Knight_Lockheed_Mart
I was able to work around the problem by copying the DAXmx to a USB thumb drive and installing from there.
(4,824 Views)
