Connection issues with USB-6008 DAQ
I am very inexperienced when it comes to DAQ and LabVIEW. We have a USB-6008 (12-Bit, 10 kS/s Low-Cost) Multifunction DAQ which has been running OK for the last couple of with LabVIEW 13. However suddenly it has stopped working. As soon as it is connected to PC via USB, it connects and disconnects continually.
I have tried a different PC and USB cables and the issue still exists. When I open the LabVIEW program, it fails to run as it cannot detect the DAQ.
Can anyone help me with this issue please.
Becky
(3,024 Views)
Hi Becky,
It sounds like a hardware issue, possibly with the USB connector on the 6008. Do you know how old the device is? Did anything happen between it working and not?
Nic
Nico
Systems Engineer
Certified TestStand Architect Certified LabVIEW Architect
(2,980 Views)
Hi Nic,
Thanks for your reply. The device is about 2 years old. do you mean the connector on the board?
Nothing happened between working and not working as far as I know.
thanks
Becky
(2,953 Views)
