Connection to NI 9205 (Displacement Sensors)
Sorry for bothering, I just need some guidance on the connection of some string and linear pots (10 total) to the NI 9205 as its my first time to deal with DAQ. I read that using differential connection is recommended if lead wires are longer than 10 ft (which is the case). If I used the differential grounded connection the input goes to A1 for example and Output to A8 but how about the ground ? I am attaching the NI 9205, String Pot and Linear Pot data. Many Thanks !
Message 1 of 1
(2,164 Views)
