Connectors for Cables
I need to purchase connectors for the following cards/cables. What connectors do you recommend/ what company(vendor)/ what part number?
1. PCI-6541 with SHC68-C68-D2 cable.
2. PCI-6509 with SH100-100-F cabel.
3. PCI-6289 with SHC68-68-EPM cable.
Thanks a lot
(4,214 Views)
Hi intern,
It looks like you already have cards and cables in mind that you would like to purchase. All of this equipment can be purchased through National Instruments, along with any connector blocks wanted. Below are product pages for each device which lists the recommended connector blocks.
PCI-6541
PCI-6509
PCI-6289
Our sales team can also help for part suggestions along with clarifying any questions you may have.
David L.
Systems Engineering
(4,200 Views)
To be honest, it didn't help at all. I have purchased all those cards and neccesary cables that go with it. All I need is the connector itself that be be used for plugging in the cable. So, just connectors, no boxes, not nothing, except connectors. Where can I find a connector for each of these three cards/cables, what vendor, and what part no.
(4,197 Views)
Intern,
Below are a few documents which give connectors and part number for making custom cables.
Interfacing to the NI Digital Waveform Generator/Analyzer using the VHDCI Connector
- This has the connector for your 6541.
PCB Mounting Connectors
 - This has 68 and 100 pin connectors.
If you need more variations, you can look at  Specifications and Manufacturers for Board Mating Connectors. This has the same part number as the PCB Mounting Connectors, along with more.
David L.
Systems Engineering
(4,170 Views)
Thank you kindly
(4,163 Views)
