Constant Temperature Anemometer (CTA)
My application is to measure the velocity with the Hot wires.
I have a Dantec Dynamics CTA (Constant Temperature Anemometer) bridge: Streamline 90N10 Frame with 4 channels.
To calibrate my hot wires and take measurements, I need to change the Decade resistance in my CTA. For this I need software to control the CTA.
Question: Do any one has a labview program to control the CTA?
Thank you so much for your help
(4,801 Views)
Hello Hach.
Do you have your instrument drivers? In first time, you will need them. You should ask them at Dantec Dynamics, maybe they had already made them. If the y don't have you should have to build them yourself.
In other points, you should tell us more about your problem you have with your code.
Thanks.
Regards.
Romain D.
National Instruments France
(4,761 Views)
