Continous data acquisition using PXI6221
Can any please help me to acquire continous data. I am using PXI 6221 and Labview 8. If I give continous inthe DAQ assistant, then also it acquite only N samples. Can any one tell me how to get rid of this...
(3,177 Views)
Put the DAQ assistant inside a While loop, thats it!Smiley Wink
Also i suggest you use the examples shipped with LabVIEW
You can find continuous acquisistion vi's in Find examples>>Hardware input and output>>DAQmx>>Analog measurement>> Voltage folder
I suggest you start with Cont Acq&Graph Voltage-Int Clk.vi
(3,174 Views)
