06-16-2006 08:05 AM
06-19-2006
03:53 AM
- last edited on
04-01-2026
08:01 AM
by
Content Cleaner
Hello!
You can use NI-DAQmx and look at some of the shipping examples with some minor modifications. You can read about these devices here which also mentions some exampled you can look at to getting started:
USB-6008/6009 Continuous Analog Output
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MtjSAE&l=en-US
These devices only support software-timed waveform generation which means that it is the software that sends a sample to the DAQ device, waits for the prescribed time interval, and then sends the next sample. So the timing of the waveform is driven by the software, using the computer's clock, instead of by the DAQ hardware. Software-timed is less reliable and has (often) lots more jitter because of competition for CPU resources.
