Continuous windows errors messages
Hi everybody,
Well, my data acquisition application runs correctly until it crashes suddenly, normally once a day, once every three days, etc. Sometimes the problem is with ole32.dll library, other times problems with NI Service Locator that it stops and I don't know why, sometimes the system generates an error (System error)... and so on....
I don't know what is the problem.....
Any ideas? I need help, i don't know what to do....please help
Many thanks.
(3,514 Views)
For service locator see this document:
http://digital.ni.com/public.nsf/allkb/8C00F1144B2CD73E86256DEF00698AC3?OpenDocument
Check that u do not have firewalls, antivirus, etc... that can be disturbing your TCP ports used within LabVIEW.
Dunno any other troubleshooting for this issue... Pls tell me which LabVIEW and operative system ar u using, also if the error happens within Labview or an exe, ar u using drivers, hardware, etc...
Jaime Cabrera
NI Applications Engineering Spain
(3,468 Views)
Hi!
I use LV 7.0 Express with Measurement & Automation 3. Also my OS is Windows XP SP2. I don't use any antivirus or firewall and I use a NI PCI-6025E with the support of other boards like 1xNI SC-2051, 1xNI CB-50LP and 2xNI SC-2062. The error happens with my .exe Application.
Many thanks.
(3,463 Views)
