Control System with MyDAQ
I would request your members and other experts  to help me with the following problem.
I am using control and simulation to track a simple step signal fed from a function generator to the PC through myDAQ . The myDAQ is set as following
voltage level = +-5V
Acquisition Mode-one sample on demand
I have connected a waveform Chart as seen in the attached simulation. But during run time the X axis of the waveform chart sets certain numbers  automatically . I have tried to resolve this issue but they are not working. hope somebody would be able to help me out from this .
Also when continues mode is set up as the acquisition mode a error message pops out as try increasing the Buffer size.
regards
Neelbrata Roy
(3,640 Views)
Hello Roy,
What hardware do you use?
__________________________________________
The best way to thank, is to give KUDOS
(2,145 Views)
