Control analog output of a voltmeter using NI-6211
Hi
I am trying to control the output on a voltmeter using NI-6211. I have tried with the DAQ assistant in a while loop wired to a control, and also tried to simulate a signal, but I could not see any changes on the voltmeter as I varied the control on the front panel. I then tried to use the example  Voltage - On Demand.vi, but that did not work out either.
Can anyone help?
Message 1 of 1
(2,636 Views)
