Controlling a Stepper motor driver with USB 6009
Hi Alan_mfi,
I would recommend taking a look at our DAQmx help file for information regarding device pinouts and information about DAQmx tasks.  After installing our DAQmx driver, this help file will be located in Start » All Programs » National Instruments » NI-DAQ.  If you simply search for 6009 in the help file, you can find the exact device pinouts for the device.  This should assist in making the proper connections from your motor drivers to your USB-6009.  This information can also be found in the online manual found here.  I'm assuming you will be using the digital I/O lines on your 6009 to control the motor driver.  Assuming this motor driver will accept the voltage / current specifications of the digital IO lines of the 6009, you should be able to control the output of these digital IO lines with a simple LabVIEW application.  I would highly recommend starting with our examples.  These examples can be found by going to Help » Find Examples in LabVIEW and navigating to Hardware Input and Output » DAQmx » Digital Generation section.
I hope this helps,
Paul C.
Message 11 of 15
(2,568 Views)
Hi Paul C.,
Firstly i want to say thanks for your replied. But here i just need to know, is that the DAQmx driver i will get with the DAQ 6009 or what?..Because now i am just installed the LabView and try to study it first. In my program, there was no DAQmx driver.
Whatever, thanks again for your infomation. if i have any problem, i will ask again.
thanks 😃
Message 12 of 15
(2,559 Views)
Hi Alan_mfi,
You should get a DAQmx driver CD with the USB-6009.  However, you can download the latest DAQmx driver (version 8.6) from our website here.  This should allow you to begin working on your application before you card arrives.
I hope this helps,
Paul C.
Message 13 of 15
(2,544 Views)
Hi Paul C.,
Thanks for that info. I am really appriciate all your helps.
I will ask again later if i have any problem.
Thank you
Message 14 of 15
(2,534 Views)
ntI want to control SSR Relay with USB-6008.my ssr rating is 5V,6mA.can i able to operate this relay as in attachment?
*****************Certified LabView Associate Developer****************************
Message 15 of 15
(2,067 Views)
