Converting Analog Outputs to Position Values Using a Piezo Controller
I am working with the Piezo Stack Amplifier (from Newman), 3 Channel, Open-loop Position Control (Model NPC3) to translate the controller's analog output to position values in microns such that an external nanopositioner can be controlled. I am using an external DAQ from National Instru,ents and the National Instruments LabVIEW software to convert/transmit the analog signals to the nanopositioner, but I am getting issues with the error in these values. The value that the Piezo reads for all 3 axes are roughly 0.2microns different from the value read by the analog input that has been converted to a position value. Would you have any idea how to use the Piezo to convert the analog output to position values?
Please let me know if you have any insight!
(853 Views)
Have you considered the Analog Input and Output accuracy specifications and your position controller?
Have you attempted to calibrate the position control system, including your DAQ as a System?
Santhosh
Soliton Technologies
(800 Views)
