Converting Two PCI 6221 to One PCIe 6323
I am upgrading lab computers, and the new ones only have 1 PCI slot.  The old computers had two PCI 6221 cards in them so I will be switching over to one PCIe 6323 to replace them.  I am using one SCB-68A and one SCC-68 connector block in my existing control/data collection set up.
What is required to make this switch?  I'm assuming I will have to make changes in both MAX and the .vi files.
Is there a reference chart that shows the old channel to new channel IDs?
(3,776 Views)
If you created tasks in MAX, they would need to be modified. Instead of tasks for dev1 and dev2, you would have a single task. The same is true in your LabVIEW code.
The pin numbers associated with a specific type (i.e. ai1) are in the manual.
(3,750 Views)
