Could I use the SCB-68 to measure the angular displacement in control pendulum system and if I could how can I use it?
I'm trying to set up a lab to review the behaviour of the control system for inverted pendulum. about the theorical part and using labview I'm good enough, but I don't know about the connections for scb-68 and ABB ASCS200(the controller to use) and connecting them together.
(4,295 Views)
You need an actual DAQ device. The scb-68 is just a dumb terminal block that can't acquire anything.
(4,285 Views)
thanks, I've provided the PCI6023E as data aquisition hardware..So
(4,137 Views)
