Could not find product 'ni-daqmx_19.0'
I am trying to download the ni-dawmx on a lab laptop and I keep getting the above error. I was able to install the package manager but the error comes up directly after. I was able to get it to download on my work laptop (HP Windows 10) but when I tried the exact same process on 2 different lab laptops I got this same error. One PC is windows 8 and the other is windows 10 and they are both Dells.
(2,780 Views)
Can you provide a screenshot of the error?
Seeing the error in context will help in the diagnosis of this issue.
Thanks!
Ramsey
Technical Support Engineering
http://www.ni.com/support
(2,753 Views)
Tengo exactactamente el mismo problema, tienen problemas con su pagina web?
I have the same Issue, please can you help me, or do you have onother option to download the entire file??
(2,449 Views)
