Counter Output Pin on PCI-6229
I am using NI-DAQmx 7.3 C API with (among others) a PCI-6229.
I have used DAQmxSetCOPulseTerm() to connect a counter output to a terminal other than the default. It seems to work- the output pulses do, in fact, appear at PFI 6 (the terminal I'm using for testing). But the pulses continue to appear at the default output pin as well.
Is that expected?
In order to reverse the situation, I used DAQmxResetCOPulseTerm() just before calling DAQmxClearTask(). The function returns zero, but if I subsequently make a new task to do pulse output from the same counter, pulses appear at both PFI 6 and at the default pin.
Am I missing something?
John Weeks
WaveMetrics, Inc.
Phone (503) 620-3001
Fax (503) 620-6754
www.wavemetrics.com
(3,124 Views)
Hi John,
I would suggest using the DAQmxTristateOutputTerminal. I have tried what you are doing in LabVIEW and I'm seeing the exact same results. When I set the default pin to tristate, the counter output does not show up on it.
-Sal
(3,112 Views)
@salvador Santolucito wrote:
Hi John,
-Sal
Thanks for trying it and confirming what I saw, and thanks for the pointer to DAQmxTristateOutputTerminal.
John Weeks
WaveMetrics, Inc.
Fax (503) 620-6754
www.wavemetrics.com
(3,107 Views)
