Counting number of pause trigger events in analog data acquisition
I am doing analog data acquisition using a digital pause trigger. I would like to count the number of times the trigger sets off and append it to the incoming data. I was thinking of doing this by routing/duplicating the trigger signal to a counter channel and then synchronizing the counter with the analog acquisition task. Is there an easier way to do this?
(2,889 Views)
Could you let us know what hardware specifically you are using? Also could you post a screenshot of the way you are currently going about it? This will greatly help in trying to help you possibly find a better solution. Thanks!
Daniel G.
Applications Engineering
http://www.ni.com/support
Daniel G.
Semiconductor & Wireless
(2,866 Views)
