Create two AI tasks for SCXI module
Hi all,
I have two SCXI-1102 cards. Is it possible to create two Analog Input(Thermocouple) tasks for each SCXI card and run the tasks simultaneously?
Raja
(3,950 Views)
Hi Raja,
You might need to add channels from both modules to the same DAQmx task in order to use both modules simultaneously.
If each SCXI-1102 module is connected to a separate DAQ board (E Series, M Series, X Series, or S Series) with a separate cable and is using "parallel" mode, then you can use two separate tasks. If only one SCXI-1102 module is connected to a DAQ board, then you are using "multiplexed" mode, which only supports one analog input task (per DAQ board) at a time.
Brad
Brad Keryan
NI R&D
(3,939 Views)
Hi Brad,
Thanks for your reply.
I have a PXI-1050 PXI/SCXI Combination chasis in which I am going to use PXI-6224 Analog card, PXI-2586 Relay Switch & SCXI-1102 thermocouple amplifier.
I have a problem in running the task that i created. I created a task for the PXI-6224 analog voltage channels and another task for SCXI-1102 thermocouple channels. I tried to execute both the tasks parallely but only one task is executed & the other task gives an error stating " Error -50103 occurred at DAQ Assistant Possible Reason(s): The specified resource is reserved. The operation could not be completed as specified."
If I execute the task seperately ie., one at a time, the task runs successfully.
Whether I need to configure both PXI-analog card channels & SCXI thermocouple channels in a same task?
How to configure the task to run parallely, if there are 2 PXI-6224 cards & 2 SCXI thermocouple cards?
Raja
(3,921 Views)
Sorry, when I wrote the previous reply I forgot that the SCXI-1102 does not support parallel mode. Only SCXI modules that have 8 channels or less are capable of supporting parallel mode. You will have to acquire from both SCXI-1102s using the same task, as long as they are in the same chassis.
Assuming that one of the PXI-6224s is in slot 8 (the rightmost slot), then DAQmx will acquire the SCXI data from an internal channel on that PXI-6224, which is connected to the SCXI part of the chassis using the PXI local bus. Otherwise, if you have one of the PXI-6224s cabled to one of the SCXI-1102s using a 68-pin cable and an SCXI-1349 or SCXI-1346 adapter, it will use the differential ai0 channel on the PXI-6224's front connector.
Anyway, if you want to put the PXI-6224 channels and the SCXI-1102 channels in the same task, here is how: In the DAQ Assistant, click the Add Channels button to add the other device's channels to the same task. If you were using the DAQmx API directly, you could specify PXI1Slot8/ai0:31,SC1Mod1/ai0:31,SC1Mod2/ai0:31 as the physical channels input to DAQmx Create Channel, or you could call DAQmx Create Channel multiple times with the same task.
Brad
Brad Keryan
NI R&D
(3,871 Views)
