Creating Task in MAX or Code
What should I consider when deciding whether to define an NI-DAQ Task in the code or in MAX for a production application?
(4,825 Views)
StevenATK,
The main difference between creating a task in NI MAX vs LabVIEW is in how you edit or create the task. Whether or not you create the task in NI MAX or in LabVIEW, the task is a part of the DAQmx API so the two aren't fundamentally different.
The following link dicusses creating a virtual channel and using it in both NI MAX and LabVIEW
(4,783 Views)
(4,782 Views)
Do you want the user to be able to change any of the task parameters? For production, I would typically not so I keep the creation and setup in the LabVIEW code.
(4,773 Views)
