Creating a retriggered analog input on M-series DAQ in LabWindows
I'm trying to create a hardware-triggered analog input task that will acquire N samples whenever I give it a hardware trigger using a USB-6229 DAQ. As far as I can tell from reading through previous posts, the board does not natively support retriggered tasks like this, so I'm supposed to create a counter which will serve as the internal clock for a second task (presumably a continuous acquisition task). My problem is that it is not at all clear how to go about doing this. I've tried going into MAX and creating a Counter output, but all options for the "Start Trigger" are dimmed. Also, I am not sure what mode to put the pulses in - 1 pulse, continuous pulses, etc. Which one of these counters is going to be hardware-retriggerable? The documentation I've found to date all mostly deals with LabView and I can't really understand how the tasks are configured based on the pictures they show.
(3,630 Views)
Accepted by topic author PaulGanssle
Hi Paul,
Try the following DeveloperZone:
DAQmx -- Retriggerable AI Using Retriggerable Counter
I'm not sure why the files have such ambiguous names--I believe the one you will want is named 3018.zip.
Best Regards,
John Passiak
(3,610 Views)
This works well! Thanks very much. Took me forever to actually get around to finishing this.
(And 3018 was indeed the correct file).
(3,507 Views)
