Current is limited on the 5V output of ni usb -6289
I measured the current and the voltage of my ni usb-6289 5V output for differents loads. I thought this output could supply 1A but the voltage drop to 3.3V for a supplied current of 100 mA althought the board is powered by an externel power supply.Is it normal?
(4,242 Views)
Yes it is a normal behaviour, you can see the digital I/O characteristics page 10 of this document : http://www.ni.com/pdf/manuals/371292g.pdf
Best regards
(4,215 Views)
Spoiler
Jean-Luc:
I think he was referring to the +5V output pin, not the digital outputs. 1A is the spec.
There is a user-replaceable fuse on the USB devices. I am not sure if this is a poly-fuse or a traditional one (refer to the M-Series User manual). I have seen poly fuses fail in such manner.
-AK2DM
(4,204 Views)
Thank you for your reply. But so :
what does usb devives 5V output 1A max mean ?
(4,197 Views)
It's the maximum current that can be delivered by the +5V pin. Check if the power supply meets the requirement.
Best regards
(4,191 Views)
It means that the 5V output pin on the USB-6289 which is pin 14 on connector 1 is the only pin with high current.
The analog output can output 5 mA, the digital output as shown in the link show above.
LabVIEW ChampionLabVIEW Channel Wires
(4,185 Views)
