Custom NI USB-6363 Breakout Board - Best practices?
Hey,
I am designing a custom breakout board for the NI USB-6363 and I had some questions about best practices
Should I have a AGND plane?
Should I connect all AGND pins together or only use one?
Thanks very much for any advice you can offer!
Cheers,
Jimbles
(2,873 Views)
Accepted by A-Guz-Man
Hi Jimbles,
-Yes
-And yes. NI 6363 comes with several AI GND pins for convenience however they're all in the same plane.
You can use this documents as useful references:
https://www.ni.com/pdf/manuals/371041c.pdf
https://www.ni.com/pdf/manuals/371805b.pdf
https://www.ni.com/en-gb/support/documentation/supplemental/16/63xx-models---daq-multifunction-i-o-c...
(2,807 Views)
