DAQ 1200 on Mac with OS X?
Can anyone recommend a solution for running a existing DAQ1200 data acquisition board on a Mac laptop running OS X? My LabVIEW version is 7.0 Express Student Edition. I would be willing to run under OS 9 if I had to, but I'm trying not to buy new hardware or software.
(3,127 Views)
You can't use the 1200-series boards on OS X. You can use it on OS 9 if you install the version 4.x (x=8?) driver. If I recall correctly, to do that you have to select custom install.
John Weeks
WaveMetrics, Inc.
Phone (503) 620-3001
Fax (503) 620-6754
www.wavemetrics.com
(3,117 Views)
NI-DAQ 6.6 for Mac OS, which supports Mac OS 9 but not Mac OS X, supports the PCI-1200 through LabVIEW. These older drivers can be downloaded here. This installer can also install NI-DAQ 4.9 if you need to program the PCI-1200 with an alternative language.
geoff
Geoff Schmit
Huskie Robotics, FIRST Team 3061 Lead Mentor
http://team3061.org/
@team3061
(3,104 Views)
