DAQ 6008 and tdms file
how can I make a recording an analog input in first .tdms file (for example in 1 second) followed by a recording in another file (for example in 1 second)?
(3,921 Views)
The simplest would be to configure the DAQmx Streaming feature to write your analog reads to a TDMS file.  You can use a DAQmx Read property node to set the number of samples to put into each TDMS file.  A new file will automagically be created once that number of samples have been streamed.
GCentral
(3,907 Views)
