DAQ 6020E VI for simple output
Hi all,
I got an old DAQ6020E (BNC) device and I'm trying to build a VI to produce several ouput waverform but I don't really know how to do. Is there any software I may use to do so?
Thanks all,
(2,887 Views)
You can try using the example finder in LabView to get you started under Hardware Input and Output --> DAQmx -->Analog Generation --> Voltage use the context help and the detailed help to better understand the example VIs.
Another more simple way is to use the DAQ Assistant express VI which can automate output generation.
Toader Mihai
(2,765 Views)
