DAQ-6363 Using External Clock to Generate Datastream
I have a clock signal on a PFI channel as an input from a generator. I want to generate a datastream, but sync it with the clock PFI channel.
Is this possible to do with a task/DAQMx Drivers or do I have to bit bang with the drivers?
(578 Views)
Yes, you can use configure PFI as the source of your Sample Clock timing.
See shipping examples at Help >> Find Examples... >> Hardware Input and Output >> NI-DAQmx
Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisition Applications
https://tmesystems.net/
(552 Views)
Thanks!
(469 Views)
