DAQ 9237
I have DAQ 9237. i am using one channel of 9237 for pressure measurement as input to DAQ. Also i want to measure one more analog signal by using other channel of DAQ 9237.
How can i use DAQ 9237 to measure other analog input signal ?
(2,610 Views)
You will generally want to create NI-DAQmx Global Virtual Channels in MAX.  Then you can create a Task that contains those channels.  You can also create channels when creating a task without creating the virtual channels first.
Check out the getting started with NI-DAQmx page.
https://www.ni.com/en/support/documentation/supplemental/06/getting-started-with-ni-daqmx--main-page...
(2,520 Views)
