DAQ Analog input
HI
i m using labview 7.1 & NI PCI 6251 M series DAQ card., SCB 68 connector box
I m trying to read voltage from the connector box & displaying it on a waveform graph
But even when there is no voltage being supplied to the connector box, i m able to c readings on my graph in labview.
& the amplitude is around 10.
wat cud be the problem.?
(3,386 Views)
Well, there is absolutely no problem Smiley Wink
Open channels can saturete/ dirft to +/- max values of the DAQ card
But, when you connect a voltage source, you do read the correct voltage, right??
(3,378 Views)
