DAQ Assistan cant find physical channels on USB-6009
Hi, I am very new to LabVIEW and working through the "getting started" tutorial.  I have the NI USB-6009, and am following the instructions in chapter four of the tutorial to interact with the device.  When I run the DAQ assistant, and select acquire signals / analog inputs / voltage, the program says  "reading system configuration, please wait".  However, it just stays like that.  I do have the device plugged in and can get responses out of it using "Measurement and Automation".  Any ideas?
Thank you,
Kyle
(3,387 Views)
Hello Kyle,
What version of Labview and DAQmx are you currently running? I have had that issue myself before, but restarting my computer fixed that issue. Does this issue persist all the time for you?
Eric
Eric Liauw
Senior AE Specialist - Automated Test | CLD | CTA
(3,369 Views)
Thank you for your help!  I restarted my computer and it worked.  I am running LabVIEW 10.0 and DAQmx 9.3.
Thanks again,
Kyle
(3,364 Views)
