DAQ Assistant Error 200320
I'm trying to create tasks and virtual channels for 100 strain gages and displacement sensors.  I am getting error 200320 when I specify physical channels from more than two modules in my SCXI-1001 rack for a task.   I do not understand the error message because I don't know enough about the electronics inside the DAQ cards but as far as I can tell I am limited to two modules per task.
I have also tried splitting up the channels into multiple tasks but then when I attempt to do a scan on all of the tasks I get a insufficient resource error indicating the tasks cannot be started at the same time.
Could someone point me to some documentation that explains the reasoning behind these errors please?
I have include a snapshot of the error and the .ini file from my DAQ.
    Michael
(2,982 Views)
Hi Michael,
I think that the document linked below should provide you with all the information that you are looking for.
Error -200320 at DAQmx Start Task with a SCXI System
Jordan D
Applications Engineering
(2,970 Views)
