DAQ Assistant Express Vi's for acquiring and generating data at the same time in LABView
Can I run the acquire and generate DAQ Assistant Express Vi's at the same time in one LABView program? I am using LABView 2010.  It is acquiring and generating waveforms to a NI USB-6009.
thanks,
Marie
(3,669 Views)
Accepted by topic author Tupaj
You can acquire and generate in the same VI but obviously you cannot generate a waveform unless you do it a single point at a time inside a loop with On Demand sampling and can live with the low samples/sec spec.
(3,662 Views)
