DAQ Assistant & MAX question
I have created a Traditional NI-DAQ Virtual Channels under MAX that read voltage.   I then go into Block diagram screen and insert the DAQ Assistant Icon.  When I double clicks the icon to find the channel that I just created,  I'm keep getting No Supported Devices Found.
I have tested the channel under max and it's working.   Is anything I did wrong??
The hardware I'm using is DAQCard-AI-16E-4 with DAQ Signal Accessory.
(3,393 Views)
DAQ assistant considers DAQmx device drivers and the Virtual channels created with  the Traditional DAQ ID of that device will not be supported
So, create a DAQmx task/global channel in DAQmx and it will appear in DAQ assistant
Hope this helps
Message Edited by devchander on 05-08-2006 07:16 AM
Message Edited by devchander on 05-08-2006 07:20 AM
(3,375 Views)
This is what I get...
1. Go to Create
2. Create NI-DAQmx Global channels
3.  Click Analog input.
4. Select Voltage.
5. No support device found.
(3,362 Views)
Hi yoyoman-
Your DAQCard-AI-16E-4 (a.k.a. DAQCard-6041E) is not supported by NI-DAQmx as shown here.  This explains why it is not being listed in the DAQ Assistant channel creation utility.
Hopefully this helps-
Tom W
(3,359 Views)
