DAQ Assistant VI does not build
I'm trying to build a VI using DAQ assistant to measure Voltage. The DAQ assistant configuration works fine and i'm able to watch the readings in real time format in chart and tabular form but once i close the configuration window the VI doesn't build up in LabVIEW.
NI MAX is able to detect and self test the NI DAQ device once i connect it which means my drivers are working fine, I guess.
I have also tried re-installing NI DAQmx drivers, but it doesn't work.
(1,656 Views)
(1,592 Views)
