06-28-2005 03:41 PM
06-29-2005
06:57 PM
- last edited on
07-11-2025
09:41 AM
by
Content Cleaner
Hello smwtcool,
The DAQ Assistant only supports devices compatible with NI-DAQmx. The PCI-6115 is supported in NI-DAQmx, but was just added to NI-DAQmx relatively recently. I'm guessing that you have a version of NI-DAQ that does not support the 6115 in NI-DAQmx. You can get the most recent version of NI-DAQ here. You should then see the PCI-6115 in MAX under Devices and Interfaces>>NI-DAQmx Devices.
-Alan A.
