DAQ Assistant "No supported devices found"
I recieve this message when I try to use DAQ-Assistant: "No supported devices found"
I have a PCI-6115 installed on my machine, it is seen by MAX, and I can generate signals on it using lower level VIs.
Any ideas?
(3,373 Views)
Hello smwtcool,
The DAQ Assistant only supports devices compatible with NI-DAQmx. The PCI-6115 is supported in NI-DAQmx, but was just added to NI-DAQmx relatively recently. I'm guessing that you have a version of NI-DAQ that does not support the 6115 in NI-DAQmx. You can get the most recent version of NI-DAQ here. You should then see the PCI-6115 in MAX under Devices and Interfaces>>NI-DAQmx Devices.
-Alan A.
(3,360 Views)
