DAQ Device
I'm currently using a myRIO and need a DAQ device that has more inputs and outputs compared to the myRIO. Could you please suggest me any DAQ devices?
(1,840 Views)
Could someone suggest me if there is a DAQ device similar to the myRIO that has 12 analog inputs and 12 analog outputs. Does that type of device actually exist? When I was searching online, I was able to find devices that that had 8 analog inputs.
Kindly Request your suggestions.
(1,827 Views)
12 AI and 12 AO will be hard to find.  Are you still trying to use the myRIO or do you want PC control?  What kind of budget do you have?
(1,819 Views)
We will also be using a myRIO. The budge is between 1000 to 3000 dollars I guess.
(1,806 Views)
If you could spend more, you could look at cDAQ series with two modules (1 for AO and 1 for AI). There are some cDAQ modules with 16 channel of AO or AI.
Santhosh
Soliton Technologies
(1,784 Views)
Or to be more similar to a myRIO, use a cRIO using the same C-series modules.
(1,757 Views)
