DAQ Diagnostic files missing
I downloaded the DAQ Diagnostic 2.1.0 program to my computer, installed it, and ran it. Everything seemed to be going fine, but it failed 3 of the 6 diagnostic steps: the Counters, Analog Input, and Analog Output sections. The other 3 passed. I don't believe that it failed because the hardware is bad. I think that it failed because some of the test VI's were missing. In fact, it looked for the test VIs in the "tests" folder in the DAQ Diagnostic 2.1.0 folder, but the "tests" folder doesn't exist. Is this a problem with my download of the Diagnostic tool, or am I supposed to find those VIs somewhere else in my LabVIEW folder?
For your information, I am running LabVIEW 2009, I have run-time 2009, I have NI-DAQmx version 8.9.5, and I am trying to diagnose a USB-6259 DAQ. I noticed that it requires LabVIEW 2009 SP1 run-time. Is this the problem?
Thanks.
Matthew Shaw
Message 1 of 9
(4,945 Views)
Did you download the installer or just the executable itself?  I'm trying to reproduce this issue now.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
Message 2 of 9
(4,928 Views)
I downloaded the downloader, which installed the installer, which installed the Diagnostic. Do you think it's because I do not have SP1 on this computer?
Message 3 of 9
(4,925 Views)
I'm able to reproduce what you are seeing, but I'm still working on tracking down why it is happening.  In the mean time, the DAQ Diagnostic Utility 2.0 should work for your immediate needs.
Seth B.
Message 4 of 9
(4,899 Views)
The DAQ Diagnostic 2.0 worked just fine. Are the subVIs not embedded into the 2.1 version? Thanks for helping me out. My DAQ unit passed everything.
Message 5 of 9
(4,884 Views)
I'm thinking that the issue is either than I'm using VIs that weren't added until a later DAQmx version or that aren't included with the base LV2010 runtime, which in DAQ Diagnostic Utility installs.  I should have a fixed version up later this week.
Seth B.
Message 6 of 9
(4,866 Views)
Accepted by topic author mdshaw16
Just to finish out the thread.  I've update the version of the DAQ Diagnostic Utility that is on the download page with a fix for this issue.  For those who are curious, I forgot to include the analysis library with the LabVIEW 2010 run-time engine in the installer, which is why this was failing.  This is fixed now.
Seth B.
Message 7 of 9
(4,838 Views)
Thanks Seth. I appreciate your good work.
Message 8 of 9
(4,835 Views)
Same issue here.. tests folder is missing.
************ Test FAILED due to an internal error ************
Error 1003 occurred at Open VI Reference in Run Tests.vi->Diagnostic Utility SubVi.vi->Diagnostic Utility.vi
Possible reason(s):
LabVIEW: The VI is not executable. Most likely the VI is broken or one of its subVIs cannot be located. Select File>>Open to open the VI and then verify that you are able to run it.
VI Path: C:\Program Files (x86)\National Instruments\DAQ Diagnostic Utility 2.1.0\tests\CTR Buffered Pulse Generation.vi
I don't see where the update that happened an decade ago, go ? Can someone help with the updated file?
Thank You.
Message 9 of 9
(2,905 Views)
