DAQ, Graphing and Saving to File from 3 E-Series-Devices
I would like to write and read analog data and save the readed data to file, from 3 E-Series-Devices at the same time in the same computer. This should be take at a frequency from only 100Hz.
Why I always get the error message 10805.
I have a buffered DAQ.
I write to 2 analog Outputs and read 6 analog Inputs at every device.
The buffer is 1000 samples, the sample rate is 100
and I read the buffers twice a second.
After 1 second comes the error.
I am confused and thanks for assistance.
(2,474 Views)
Are you using an external clock? If you are then noise on the clock line can cause this error.
Check out:
http://digital.ni.com/public.nsf/websearch/5E43E334761325BE8625616B006F4CE6?OpenDocument
This KB contains information on this error and techniques for resolving the issue.
Kevin R
(2,474 Views)
